- May 6, 2016
- 74
- Vinyl
- Pentair Intellichlor IC-40
Perhaps this is a "talk me out of it" but I have a simple Pentair pool system with one skimmer, one waterfall, one gas heater, Quad-DE100 (means I only have to backwash or clean it when closing each year), Intelliclor-20, Aqualamp Rainbow Rays LED Pool Lights (x2 on same circuit) and two stair jets for a "spa-like effect" (my installer who was a great guy, went awol years back). Chemistry & water-quality is always great, I enjoy manually vacumming the pool as I have done for decades otherwise. It's an L-shaped pool running since 2015.
SO I can program the Intelliflo VS with it's own timer (but not remotely, but that would be nice for certain purposes), I can control the LEDs remotely with a basic WiFi system, but really one of the main things I wanted to do is be able to automate the waterfall. UNfortunately it is plumbed into the whole return system (has it's own valve), so basically the return from the heater goes to a pipe split three ways with three separate valves, first the stair jets (to improve flow when needed), next the Waterfall (which DOES require most of the pump's juice to have a significant flow), and the pool return jets.
Problem is, if pump goes into a lower RPM and the waterfall happens to be on, it will simply dribble (especially if stair jets aren't shut down), and that dribbling does cause some water loss.
I don't have the budget to go whole hog, but even a simple amount of automation to the pump, heater and a couple valves would be groovy.
Would the Pentair Intelliconnect at CDN$500 be a bad choice? lol (Thank you in advance!)
