Wanted to share
I documented my issue here:
www.troublefreepool.com
Small specs of black algae on the plaster and grout. Pool had been SLAMMED to 100ppm for 20 days, FC kept elevated etc. Pool always passed the OCLT and CC always 0. Dealing with this for the last 5yrs. Frustrating as everything is 'fine' but for the accursed specs of black algae
The algae started coming back this spring as usual, soon as water got above about 60F, despite holding FC at 10-12ppm. Which seems excessively high already. I did a ton of reading and honed in on phosphates. Experts say it's irrelevant, others claim getting rid of the phosphates cured their issues.
Nothing to lose except a few $$, so I bought a couple test kits and verified the pool was at about 600ppb phosphates. Present but not high by any means. Purchased a quart of Orenda PR-10,000, did the math, threw in half a quart. Flocculate it did. I let it work and after a couple days I swept as much as I could into the drain, then backwashed, disassembled & 100% cleaned the filter, put it all back together. Maintained 10-12ppm FC throughout.
Here to tell you, the black algae is GONE. All the little pinheads in the gunite, and bits of algae in grout imperfections, vanished within a few days. Like it was never there. I've let the FC drift down to 5-7ppm and all is well.
YMMV. I am super happy
Good luck and I hope this may help someone dealing with a similar maddening issue.
VERY SAD: Return of Black Algae after SLAM
The Setup: SWG Gunite pool, plaster is 13yrs old, well cared for. But some areas of degrading tile grout esp around skimmers. Typical reading before SLAM (I kept it pretty consistent): FC 5 CC 0 pH 7.7 TA 70 ch 400 CYA 80 Salt 3000 Daily sweeping/skimming. I do 100% of the maintenance and use...
