Getting hang of app but CH is low always any suggestions
BuffLosolja
58
Atlanta
Jandy Aquapure 1400
I have a Pebbletec pool and I have been told that I need to keep CH up but I hardly get it at 150. I am love the kit and app but still struggling with this. I want to thank everyone because you have made this journey fun. I'm attaching pic of numbers and all for today any input would be greatly appreciated.
Picked these up looking up contents they had them at Ollie's for $7 each. What is recommended time of adding calcium before letting people swim?
They can be in the pool when you add if you wish. Add in small amounts. Check the one that says Calcium Plus to be sure it is pure calcium chloride.
Thanks it is 94% Calcium Chloride and 6% other the other HTH doesn't have any content information.
Calcium chloride dissolves in water quickly, but you could dissolve it in a bucket of pool water or even tap water beforehand and then pour the liquid solution in as you walk along the side.
Reactions: LoneWolfArcher
I too have trouble keeping calcium up, having extremely soft water. You are probably going to need more than you show in your pic. It took 12 lbs to raise mine 75 ppm, my pool is a bit bigger than yours, but I started at 275.
Use pool math effects of adding to figure out how much you'll need.
Listen to pool gate and just broadcast it in The deep end. Add 1 bag then brush till dissolved, continue till you have added all that you need.
