- Mar 5, 2020
- 3,160
- Plaster
- Astral Viron V35
Totally agree. Most people don’t want to know how anything works . . . until it doesn’t. But unless and until that happens, most people live in a blissful ignorance and there’s a point where I have to join them lol. When Armageddon comes, I anticipate a drain and refill and back to five elements . I’d like to believe I understand them, at least enough to go on to something else. From what I’ve seen, when it gets more complicated than that, it becomes a fight of competing constraints and it’s really time to start over anyway. Where it gets really tough is when the refill water is part of the actual issue and even just starting over doesn’t work. Then the rocket scientists need to get called in to help. My fill water is benign and climate here produces enough but not too much rain so I count myself lucky .Sometimes it is rocket science.
It's all well and good as long as everything is working, but when you get an unusual issue, then it takes more than a "simple" understanding about what's happening.
"Everything should be made as simple as possible, but not simpler". - Albert Einstein
Apparently not . Rocket scientists aren't any smarter than the rest of us, science saysIs rocket science actually rocket science?
Here here! With you 100%! But can I also ask we all appreciate the 99.999% who do stuff that needs doing mostly anonymously grinding away while not understanding at all the remarkable infrastructure that makes, say, their cherished internet social media on a mobile phone work lol. I was taught long ago that basically everyone involved is needed for mission completion and I’ve always tried (often failed) to appreciate everyone’s contribution.Most people do not understand how 99.999% of the world works.
We use our cell phones and it seems so simple; and it is from a user perspective, but the magic behind the scenes is incredible.
We go onto Amazon and click a button and stuff magically appears at our door faster than we can run from our computer to the door.
It “seems” simple, but the computers and logistics that happen behind the scenes is beyond the understanding of almost everyone.
We ask Google any question and it answers in a quintillionth of a nanosecond and we just take it for granted.
Google maps tells us exactly where we are and guides us to our destination using satellites and clocks accurate to a few picoseconds.
All human progress depends on going beyond “simple” answers and into increasingly complex answers about everything.
Let’s take a second and really appreciated the intelligence and complexity of our everyday world that is handed to us on a silver platter by some very intelligent people doing incredibly complex things.
Haha. Yes. This discussion also brings to mind one of my favorites: Kipling, "Sons of Martha" on the role of engineers. A few lines I can't read without choking up.The progress paradox told me long ago that the reasonable men adapts himself to the world; the unreasonable man persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. -Shaw. Most people find me unreasonable so I guess I’m doing my part lol.
Raise ye the stone or cleave the wood to make a path more fair or flat;
Lo, it is black already with blood some Son of Martha spilled for that !
Not as a ladder from earth to Heaven, not as a witness to any creed,
But simple service simply given to his own kind in their common need.
And the relative velocity time dilation.you have to consider and understand gravitational time dilation.
Doesn’t your RJ 60 have a translucent housing? I can clearly see the status of mine. Circupool sells a replacement electrode so it must be fairly easy to remove from housing. FYI replacement cell is cheaper than just replacement electrode, go figure.Matt these plates are locked in tight and offset in this cell housing. Opening it up with a sawsall or hammer would be the only way to get a good look. Hard to imagine how the Ruthy coating could have been damaged that bad, that fast to cause this situation with only zip tie cleanings all of season 1and only recent use of 1:10 MA solution in addition. If I can limp this cell through until winter perhaps I can send it to CPool for evaluation.
Right now I am monitoring the cells performance and hoping the problem does not repeat.
Cena-sea, there is a polarity shift occurring at each new cycle that can be confirmed reading the voltage and amperage display. The cycles run just over 200 minutes if I remember correctly and my system is set at 65%.
Thanks for all the mind power here. It difficult for me to hash this out with the retailer due to the unique perspectives and so many potential issues possibly involved.
My Taylor K-1106 PO4 test kit arrived and my pool water tested at 2000ppb.
I just applied 21.6 oz of Oredna PR-10,000 per the instructions and the "Pro Tips" listed on their product web site. The water column has already reacted and is a milky blue and I will have another look in the morning for precipitates. Once I think the time is right, maybe several days, I will release the bot and start the extraction process. I will also monitor my filter pressure and am prepared to clean the grids if warranted.
We do get wind events that introduce dirt and leaves into the pool and we also have many grandkids 5 and under that could introduce PO4. I believe a significant factor may be wild fire ash which has been significant the last several years. Regardless the process is underway and soon I will have the recently cleaned cell generating Cl. For how long? We'll see.
The is from the product site:
It reacts with all known types of phosphates on contact and hardens them into a fine precipitate, which falls out of solution. The inert phosphates then floc out, to be vacuumed or filtered out of the pool
