My SWCG has become unreliable.
After cleaning #2 in as many days the cell had a low salt shut down after another 8 hours at 65%. A clean cell, normal high salt (4500ppm) reading in the morning with a strong amp number falls off after several cycles and finally shuts down mid afternoon with a salt ppm of 2000. Water temps from cell sensor start at 85f in the am to 92f when it shuts down. Once removed the plates are full of soft scale 90% of which can be hosed out.
The cell is producing the expected rate of chlorine when its running. I have assumed the unit is cycling the polarity properly and I have observed the amps displayed in + and - but the voltage is not displayed as negative when the amps are negative. I will need follow the cycle times closer to be sure what's going on. Not sure now if this is a controller issue, a cell issue or a sudden water chemistry issue. So many rabbit holes. I will reach out to CPool next week if I'm still stuck.
I have done nothing to change the water chemistry this season other than keep my pH at or below 7.4 and that follows a top off of my source water which is north of 150ppm. My water chemistry has been the same after lowering my TA in the spring of 2021. This sudden cell fouling is a new issue. Typical cell maintenance for me is 30-45 days.
I have pulled the cell and cleaned it again this time using the CP recommended method. I will install it again Sunday night and try a night run. When this system works (for 1.5 seasons) it is a wonderful thing, when things go sideways it can get ugly in a hurry it seems.
Stocked up on 10% liquid and still have a half a bucket of Tri tabs so I will make it through this issue, but what a hassle.
