- May 20, 2023
- 45
- Plaster
- Pentair Intellichlor IC-40
Hi All,
I have some thoughts and questions that arise usually and am curious what everyone else would do in specific situations.
Run down
I have
37000 gallon pool with an attached spa
SWG is intellichlor ic40
Runs about 12 hours in a day on 65%
My typical maintenance includes a CONSTANT ph reduction. I would say every week my pool needs a half gallon of Muriatic acid at least. I have a spillway and boulders below water level and I think this always raises my ph.
This is not an issue, really, though I wish I didn’t have to do It. But I also have read here that unstable ph isn’t great for chlorine holding.
If anyone can comment on the above, great. If it’s just part of owning a pool then just move on to below. I’m more curious about this.
More importantly:
What does everyone do for general maintenance on a FC level. So for example let’s say there’s a big storm, or a heavy load of use from a party. What should I be doing on a preemptive basis BEFORE even testing when I know there’s an added need for extra chlorine.
Should I put liquid chlorine in that night before even testing for FC? Or should I put in cap hypo shock?
Or another example if I feel like my SWG is not working or I am unsure, in order to maintain my FC levels, should I put in a certain amount daily to make sure I don’t have problems that arise?
I hope you can understand my question. Thank you all!
Run down
I have
More importantly:
