I'm trying to figure out why the FC level in my in-ground spa is dropping. My IntelliChlor SWCG runs for 2 hours/day (@ 1800 rpms) with the output percentage set at 25%. The 2500-gallon spa is covered with an auto cover. Over the past week, I have added liquid chlorine to bump the FC level to 3 ppm. With each dose of liquid chlorine, I raised the SWCG output percentage incrementally from 10% to 25%. During this one-week period the spa has remained covered & unused. Yet the FC level drops from 3 ppm to 1 ppm every couple of days. I might add that the ambient temperature have been between 88F - 100F.
Although I could continue to increase the SWCG output percentage or the runtime, I wanted to check with those of you who are more knowledgeable than I. Ant thoughts on what might be causing the drop in the FC level would be most appreciated. Thank you kindly.
Kit
Kit
