Hello to All,
I have read [somewhere] that using the natural gas heater during winter temp's is ok as long as the temp's do not go below XX? The questions I have stem from not only the air temp, but water temp, and some common sense operating instructions.
Read my manual, but it did not state anything other than do not operate during "freeze-mode" like temp's or below. The main objective I am trying to achieve are operating conditions and operating procedures that do not: crack the heat exchangers or damage the system. I always do a spa FC & pH test before operating.
So, what pool temperatures, either water or air bring potential damage if operated?
Once I have the spa/heater operating, my max temp setting is 100. I sometimes turnoff the heater [from my remote] btw 95-99 if I feel it's warm enough. Also, when I am done w the Spa, I always run the SPA/Pump w heater in off position for 10-15 minutes at a min. Once done, I'll change from SPA to POOL mode and run FILTER PUMP at a very low speed from the spa spillover to allow for a slow water temp equalization.
Thanks for your feedback, and I hope all the TFP owners that have experienced freezing temp's, that you experience little to no problems at all.
Regards, tstex
Regards, tstex
