Good morning. Glad you're dealing with a clear pool, however you got there
Once you get your cya added, please note, it will not show up in reading for a week, so don't bother testing it again for a while after you add it. However, if you've added enough for example, 30 or 40 ppm, then assume its there and use that for your FC guideline.
Bring your ph down right away but don't worry too much about the TA until after the party -- TA adjustments take a while and aren't mission critical, and you won't want to be muckin with all that pre-party
Lastly, make sure your FC is at the recommended level (see cya:FC link in my sig) and you're good to go.
You have a vinyl liner, so your low CH doesn't matter. You might want to add the vinyl liner piece to your signature, btw
Have a great weekend!
