We survived the big freeze in Tulsa last February with minimal damage...moved across town to a new house and pool and two days of cold temps have already caused problems. Freeze Protection is working for main pump and everything seems to be running well. However, the booster pump running the cleaner is covered in ice this morning. Thaw it out and see if it will run continuously from here on out (through cold temps) or drain the equipment pad and pool (below skimmer?) until it warms back up? I thought the main pump would push enough water through the system that we wouldn’t have this issue. Not so much.
