Hi guys,
Because we end up draining or pool every year (long story) this year we are going to just use chorine punks in a floater. This will be extra helpful because I will be traveling a lot this summer.
Anyway, the pool is almost refilled with fresh water and I have a question about the order of things. For now, I'm just using the local pool store to get the water correct. I have two things of shock to add once the pool is full.
But my question is, should I take a water sample to the pool store before I shock it, or 24 hours after shocking, 48 hours? Does it matter? If I remember correctly, the shock level will cause the other readings (ph, etc.) to be unstable?
Also, how quickly can I attempt to correct things? Add something new every 12 hours?
