Fresh fill and already have high CC
Jun 16, 2018
30
FORT CALHOUN
I have an above group round 10ft bt 30" deep pool. Filled with well water that is really high in Iron. I added a cup of bleach to begin with, no conditioner yet, and I added Metal Out to it because the water was yellow as a fresh fill. I guess I just need a hand I balancing everything out... Here's my levels
Fc-2
Cc-10
Ph-8.4
Ta-130
Cya-0
I have been running the pump 24/7 and been changing/rinsing out my filter daily to try and get the iron out- and for the most part it's clear with just a tinge of yellow.
Do I slam first thing? Is that what I missed?
Thx!!!
I can't find if the metal out contains sulfamic acid. It contains phosphonic acid, which is common, but it might also contain sulfamic acid.
The CC number seems unlikely. You really need a good FASDPD test kit.
That kit gives you a Total Chlorine level, not FC and CC. You in all likelihood have just been nuking your water...
You said you ordered a TF-100 last year, where is that kit?
I don't know it it matters, but I have had a solar cover on it since putting in chemicals.
So at this point what is my next step? Besides getti g a better test kit. I can't find my tf100 kit.... ?‍♀️
And I guess this isn't accurate, but I was told(I can remember by who) that when you're testing the chlorine, the immediate results are the fc and if you let it sit 5 min, you will get your CC level.. So that's what I've been going by. I'm still so new at this...
