- Nov 28, 2020
- 269
- Plaster
- CircuPool RJ-45 Plus
I have had my CircuPool RJ-45+ for a year, and the maintenance light has never come on. I do see some scaling on the cell, not completely, just some. Right now it is not generating much chlorine (my chlorine level is down to 1 PPM running at 50%, whereas it had been around 4ppm to 6ppm running at 25% to 30%). My CYA had gone down to about 50ppm but I just added two lb stabilizer, but I don't think that is enough of a decrease to justify the low output. My salt level was at 3200ppm and I just added one 40 lb bag of salt which should bring it to 3500 to 3600 ppm. I am thinking the maintenance light is inop. What is a regular cleaning schedule for a swg cell like mine?
On a second note, my pool temp is currently 86 degrees, and my Taylor salt test would not progress past the murky yellow to the salmon/brick end point, no matter how many drops I added, so I got my salt readings from a sample I brought to the pool store. Is there a temp range the test doesn't work? Should I wait for the water sample to cool to room temp?
(Added note, we have had near one month of temps in the 90's, a lot of it 95+ here in the deep south)
