Hello Everyone,
I am contemplating adding some drainage around my pool and would like your thoughts. Our backyard slopes downward where the pool is. So there is about a 3ft drop from the back of our house to one side of the pool which is 20ft away. I would like to address this runoff and an underground stream.
I am going to install gutters on the back of the house and drain the runoff to the back of the yard. So this will be a big benefit. But what else to do?
1. Should I install brick pavers along the edge of my concrete deck to dam up the water which runs off the deck? I could then install drains in various places and drain this runoff away from my pool versus letting the ground soak it up. This of course would only suffice to drain water coming off the deck.
2. Should I instead run a french drain along the side of my concrete deck? This would help drain water coming off my deck as well as water coming off the yard? This would seem the best solution BUT how would I insure no water draining off the concrete deck would seep behind the french drain and run under the deck, which is what I am trying to avoid?
3. Would you do both or is that overkill? I realize you cannot see my yard but I just want to remove as much runoff as possible.
Lastly, I had the pool liner replaced last week and we discovered a small underground stream running beside or under my pool. They had to install a pump (submerged) in the deep end and constantly pump the water out in order to make necessary repairs and then install the new liner. After all the work was complete and the pool nearly full, they then unplugged the pump and hid the cord behind the liner in one corner. The pump will only be used again when a new liner is installed.
This seems to be a common issue. Would you do anything to address this underground stream because my pool contractor didn't seem to think it needed addressing or could be. I mean would you install a deep french drain beside the pool or would you consider vertical french drains? They were pumping about 1 gallon per minute of spring water while working on our pool, btw.
God Bless,
Ralph
God Bless,
Ralph
