DB-Cooper
- Jun 18, 2019
- 594
- Plaster
- Pentair Intellichlor IC-60
Also, some lessons learned. If I had to do this ALL over again, I’d have during the day done:
1. Backwash/rinse filter which also would serve to bring water level down to give more clearance to the coping (some of my ice shelf chipped two pieces of coping (purely a cosmetic issue)
2. Pull skimmer baskets
3. Open all valves, vent the filter to recapture as much water down through the plumbing
4. Dump heater and then pumps then lower filter plug
5. Open all glass see-through ports and check valves and leave them open
When I saw my cracked pipe during thawing, I noticed all my see-through ports and check valves had softball sized ice in them. When I removed the front plates, it gave them an area to expand. When I pulled the rubber check valves, I heard/felt/saw water rushing down the pipes, would've been nice to get more of that water through the check valves before the storm.
