I’ve just discovered my automated return valve apparently had a leak that froze into a nice icicle. In pool mode it’s set about halfway to allow spillover, and water is still flowing from all returns. Should I let it ride as-is, or should I shut everything off and drain? Have another 24hrs below freezing and then freezing nights after that.
Would a valve rebuild kit likely fix the leak, provided the body isn’t cracked? If the body is cracked, looks like I’ll have to replace a lot since nowhere to cut out this valve body. Thanks!
