My pentair pumps go into freeze protection mode when the temp drops to a certain temperature. I understand that the unit has a calibration adjustment for the temperature, so I want to verify/ adjust it if needed. Question is which temperature is used to trigger the freeze protection, water temp, or air temp? I just recently had the pump casing replaced due to cracking, so I am wanting to make sure this is correct.
