- Apr 21, 2023
- 153
- Plaster
- Pentair Intellichlor IC-40
Is there a pump speed and cam setting that any of you would recommend? Is there an article that goes through this?
I did exactly this yesterday as my water temperatures were getting nervously too low. I didn't want water sitting in pipes for 15 minutes at a time. For me, I just put both my 2-way valves into service and manually put them in the middle. I then monitored my spa, and I saw that it was slowly draining, so I adjusted the valve to about 1/3 spa suction, 2/3 pool suction. I also have a manual close valve on my main four pool returns. I manually closed that to maybe 80% open.The ice on my water features were restricted by the icebergs. The pool and spa pump was working just fine.
I have a pentair intellicenter and would like to over ride the freeze protection to set it on all the time but cam the pool and spa valves to keep them running. Is there a pump speed and cam setting that any of you would recommend? Is there an article that goes through this?
I also live in the DFW area (Bedford)
Backflow for your auto-fill?Me too. Unfortunately, my back flow valve cracked and I've got a frozen solid pool. Hopefully I drained the heater and pump in time.
Thanks Jim, my pump is connected to both the pool and spa, the pool jets are also connected to spillover so water pushes out of my spa and into the pool. When in spa mode then it stops and circulates the water in the spa.WW,
I don't have a spa and my 3 HP IntelliFlo pump runs 24/7, mostly at 1200 RPM..
I also live in the DFW area (Bedford) and have never had any ice in my pool, even during the big freeze a couple of years ago..
I have a waterfall wall with three falls.. In the winter I shut the whole thing down, and partially drain the line, so that any water is just below the ground level. Running them in a freeze, makes zero sense to me?
If I had a spa, during any freeze period, I would shut off the spa spillover and let the automation automatically switch between the pool and the spa modes. Having the spillover run during a freeze, makes zero sense to me!
I do not have a heater, so running at 1200 RPM is plenty of flow for me.. I assume you have a heater and I see you have a SWCG.. What speed is required to turn on your SWCG?? I assume 1500 to 1800 RPM.. I believe that running at the same speed that turns on your SWCG should keep your pool ice free..
So does Jim's. Unless your system is a unicorn, it was plumbed the same way.Thanks Jim, my pump is connected to both the pool and spa, the pool jets are also connected to spillover so water pushes out of my spa and into the pool. When in spa mode then it stops and circulates the water in the spa.
I have a swcg but doesn't that shut off when cold water is detected?
