Hi all!
Well since my pool has been opened for a few weeks I thought it best to do a water test using my TFT100 test kit. Originally I used my chemicals from 2 years ago that have been good the past 2 years. I performed the initial drop test in theyellow side of the block doohinky, as well as the pH test on the other side of the doohinky. So as soon as I started the drops on the yellow side for chlorine, it turned Amber Orange. So in my mind it was just old chemicals. Better get a new test kit! The pH at that time was about 8.2. So I ordered a new test kit. Well it came today. I tested again. Again Amber Orange for the chlorine. And now 7.8 for the pH. The cya tested at 100 or more. So I did the other chlorine test and it took 98 drops to get the solution from pink to clear. And then I tested chloramines... barely any.
Since opening the pool we have added 3 gallons of liquid shock and filled the chlorine tablet chlorinator. Our pool is approximately 25,000 gallons, or 18' x 36' with a 9 ft deep end.
Any thoughts??
Thanks in advance!
Any thoughts??
Thanks in advance!
