Free Chlorine 0
Jcsmith9
166
Birmingham/Alabama
Good evening guys,
Just had a week of heavy rains and just been so busy I have not had time to take care of the pool like I always do. Tested my water tonight with the test kit and PH is showing a little high 8.0 (probably from all the rain) and my chlorine read 0 which I’m thinking from all the rain. Pool is cloudy but still blue. Brushed and I can see some algae on the wall but like I said it’s not green. It’s still there though. Pool math said to add 307 oz of liquid chlorine. All I got is 128 oz of liquid chlorine that I went ahead and added tonight. I’m new to this slam process. I don’t have any more liquid chlorine. What should my next steps be? Wait till the morning to test again to see where the chlorine is reading and add more? Also, I have granular shock. Would it be ok to use that even though liquid is preferred?
How are you testing your water?
If you don't have recommended kit, order one. You need one to safely slam. Link-->Test Kits Compared
If you don't have one, add 3ppm LC per day until it arrives.
If you have a recommended kit, print out the slam process, read it three times and keep it with you, having paper copy will help. Link-->SLAM Process
Use liquid chlorine. If you need to find liquid chlorine, find it. Walmart Pool Essentials liquid chlorine, Ace hardware CDS liquid chlorine are good choices.
You really ought to spend the $7 and log your pool math results. The rain didn't cause any of your issues; just inattention, which we've all been guilty of from time to time.
You have to maintain a proper amount of CYA, then keep your FC above minimum per FC/CYA Levels.
Posting a full set of results from your test kit would be helpful.
