Hello everyone, I just wanted to share this with you all.
I have had ongoing issues with metal staining in our pool. Following my last stain removal treatment in May 2017 I have been using an HEDP sequestrant, first as an initial dose, then 250ml per fortnight. However as brown rusty stains are still re-appearing (see photo) – I concluded either I’m not using a sufficient amount of sequestrant often enough or perhaps there’s an unknown source of metal being introduced to the pool.
We are on town water and when I had the tap water tested at the local pool shop in May 2017 it showed iron @ 0.3ppm and copper @ 0.8ppm. Pool water test on same day showed iron @ 0.2ppm and copper @ 0.1ppm. My last pool water test from the pool shop was August 2017 and the levels were iron 0.1ppm and copper 0ppm. Up until I began doing my own testing in July 2017 (thanks to TFP) these levels always hovered between 0.1-0.3ppm for iron and 0-0.1ppm for copper.
We have no handrails or anything metal in the pool apart from the screws on the light which show no signs of rust. I removed the pot plants from the pool yard thinking the water that drains from the bottom may be going into the pool - unlikely but very heavy rain may have made it possible at times.
I then bought some thick white socks and attached 5 socks over the end of the hose prior to topping up the pool (with hose placed into skimmer with the pump running) so that any water introduced goes through the filter before entering the pool. The first time I did this I was very surprised to find all 5 had a brown tinge to them! See photos before and after use. Each time I top up I use the socks and over time they have become very stained.
It turned out the tap fittings of my top-up water were to blame. I had a galvanised fitting along with brass taps and it seems these two metals don’t “play” well together. I had a plumber change all fittings to brass (including new taps) and it was amazing to see the amount of rust and crud build-up within them. Following the changeover of fittings I ran a lot of water through the hose onto the lawn to aid in cleaning out the line.
I have since topped up, using new socks over the end of the hose, and the staining is greatly reduced. I may not have solved the problem entirely but believe I have certainly reduced my staining potential.
I intend to have a pool store check my source water again – it will be interesting to see if there is a significant change in the metal levels.
I have had numerous compliments/comments about how beautiful and sparkly my pool water looks and I tell everyone about you and how helpful you have been to me.
I will do another post in the future outlining what I have learnt since joining you which may be useful to newcomers. Thank you for this wonderful resource.
My current test results:-
FC 8
CC 0
pH 7.5
TA 60
CH 290
CYA 80
Salt 4600
Pool Temp 26.5°C
CSI -0.66
FC 8
CC 0
pH 7.5
TA 60
CH 290
CYA 80
Salt 4600
Pool Temp 26.5°C
CSI -0.66
