mguzzy
Yeah, How does that saying go... "Idle hands install a SWG, so they can be more idle"Great idea...I'll get a pic ready and post it shortly (can you tell I'm getting somewhat anxious to do something?? lol)
When you get ready to putl the trigger.. heck even now, post up a pic of your equipment pad. There are some very creative thinkers on the forum.. Adding the two items for an SWG (controller and cell) may be easier than you think. I'm just thinking ahead for you
Anthony, my experiences with WWM were in the return lines, not on the pool walls. I could see the flakes coming out the returns. In fact, the year i converted, I still found some WWM coming out the lines, so I went into a line clean operation to get rid of it. I isolated the return lines by breaking open the line downstream of the filter, capped off all returns but the farthest, added a vertical extension to that, flushed the isolated line with fresh water, then added some of hydrogen peroxide to the isolated line. Let it work for a while, then blew out/flushed the isolated line. The peroxide is strong; be sure to use safety gear if you do this and be careful. Do not get careless.
OMG.. that thing just gave me a nightmare flashback... I was so glad to get rid of the one I had from the original pool install when moved into the house. I redid the pool equipment in 2005 and took it out. Years of gorilla pool service men had stripped the belt clamp, The filter vanes were in pieces inside the fabric bags. When I moved into the house and disassembled it the thing was clogged with DE.. The previous oweners/pool guys only ever back washed it.OK....so here's the equipment pad.....note the original '89 apollo VA-52 filter. Still going after 31 years! No plastic parts on that one...
I have happy curses all the time.we at TFP can make you curse with joy too!
Holy old-filter Batman! I’d love to see inside that thing next time you clean it.
‘How old is your filter ?’ ‘Well for one thing, it’s named after the moon landing........ ‘.I do I have NO plans to get rid of the Apollo VA-52
As to adding a SWG... you've got LOTS of room. That long return line from the heater would easily accommodate the cell and flow switch. And the control box can be mounted on top of the post or on a little extension.
then again, they built stuff to last back in the day...
I did not have the advantage of the previous owners taking care of the equipment as they should.. so by the time I got to it It was being held together with binders twine and duct tape. Our's did blow apart a few times and did flood the yard, and did partially drain the pool. So I was ready for some newer technology. I took out all the pool equipment and put in a new heater, filter, pumps and SWG.. well it was new for 2005. But it was a new enough jump that all that stuff is still easily serviceable. Kudo's to you for keeping it going. Hopefully it will last another 30 years laterI don't have any vanes. I have the VA-52 10-grid assembly, which is great shape. Both sets that I have were in the cleaning fluid this season already. My belt and clamp operate as well as when new. All I've done in that regard is to replace the nut - and have lots of extras that I'll probably never need. I've replaced the o-rings on the backwash handle, and a local pool tech had to re-solder the connection from the filter to the return lines following a real botch job when the pool store used a fernco fitting on the pressure side of the system. The d**n thing literally blew apart and, had we not been home, the pool would have emptied, flooded the yard, and likely burned out the pump.
These curse words he used concerning the pool were always words of joy as he loved his pool once again, not like how he stressed about it when he used Baqua.
I promise you @anthonypool89.....we at TFP can make you curse with joy too!
Yeah well I suspect it ain't gonna be me swimming in whatever water it may still be filtering 30 years hence
