Converted to SWG this year on opening.
Used bleach for initial chlorine to get to SLAM level and then also had SWG (IC40) at 100% for the last few days.
Water clearing up now - no longer dark green just teal/cloudy and getting better day by day. Not unusual for me for the sand filter to clear up this slowly on opening.
However the surface of the water is COVERED in foamy blotches almost looks like an oil slick.
only thing I have added to the pool since startup:
1. Liquid chlorine for initial SLAM
2. 520 lbs Morton pool salt
3. Clorox brand stabilizer
4. Sodium carbonate for pH adjustme
5. Baking soda for TA adjustment
I’ve never seen this before on my pool. Only thing different from prior years is the salt and the CYA granules (usually I’d get my CYA by using trichlor on startup).
I did use an old sock to put the CYA granules in and hung it in front of the return jet. Could there have been residual detergent/fabric softener and that’s what caused these bubbles?
more importantly - how do I get rid of it??
Latest test results
CC 0.5 (maybe not even - could barely see any pink color prior to the first drop)
FC - 15 (went up from 6 with SWG running 100% for 1.5 days)
TA - 100
PH 7.5
CYA - 40-50
CH - 75
thanks,
Matt
Latest test results
TA - 100
PH 7.5
CYA - 40-50
CH - 75
thanks,
Matt
