Today I added some liquid bleach & muriatic acid to my 2500-gallon inground spa with the pump running at about 3,200 rpms. Nothing unusual. However, for the first time, I noticed that there was a layer of foam bubbles on the surface of the water as the jets were running. When the jets were turned off, the bubbles disappeared. In the 5 years that I have had the spa, this was the first time this has occurred. I might add that the rest of the chemistry was spot on.
Could someone kindly give me an explanation? Thank you so much.
