Want to make sure I have this 100% right as I'm hoping to install my 21' round pool this weekend. I'll be using 3/4" tongue and groove extruded polystyrene foam and also Gorilla pad.
1. Start with level base.
2. Place pavers flush with level base, 100% level between each paver.
3. Put bottom track in and stand up wall.
4. Put down XPS foam, triple tape seams, make sure snug fit around walls.
5. Cover foam with gorilla pad.
6. Put on foam wall covering with spray adhesive.
7. Mount foam cove with self adhesive tape and spray adhesive if needed.
8. Install liner.
Is that the correct method? I will only lose ~1" of depth and the legs and bottom track will be flush to the ground all the way around.
Thanks.
8. Install liner.
Thanks.
