Not pool in signature:
Helping a client with a vacation home in Florida. Pool was refinished in dimond brite about 6 weeks ago with new equipment on the pad which includes a HP for the shoulder season. Client says pool contractor said not to use the heater for 90 days as it can "discolor" or have an effect on the finish which I've never heard. Is this truly an issue, please fill me in.
Secondly and thirdly;
I enclosed pictures of the before and after (was not involved in any of this until this evening)
a) There is an area where there is staining on the new deck which I've highlighted in the red but the same is more or less all over the pool deck around the pool area where the new screened in part will be. As you could see in the "before" pictures the original pool deck consisted of some kind of brownish loose stone. The highlighted green area which is now tiled was a grass area before this restoration which has no staining at all. Process of elimination tells me the staining is bleed through. The deck tile is porcelain and the rep came by and said they believe it's bleed through. The pool contractor says he's never had this problem with similar restorations. He tried cleaning it but staining keeps coming back so obviously this is a reaction of some sort possibly the mortar reacting with the stone. The guy is licensed, insured and bonded as this is a HOA which I believe is a prerequisite.....
Does my client contact his insurance directly or how does this get worked out.
b) To me it doesn't seem like there's a expansion joint. Is this a problem in Florida too.
Any help is greatly appreciated, Allan.
