Error purify off / Check flow
ProblemChlorine generation has stopped due to insufficient water flow.
Typical Solution
1. Turn on the circulation pump.
2. Turn the control valves to the correct position to allow water flow through the manifold.
3. If installed, check suction type vacuum cleaner for blocked or restricted water flow.
4. Check and clean the skimmer basket.
5. Check and clean the pump basket.
6. Check and clean or backwash the main circulation filter.
7. Clean the AutoPilot® manifold screen of trash or debris. For instructions to clean the screen, test theflow switch, and clean the bypass valve refer to the "Maintenance" section of this manual. See "TestTri-sensor Flow Switch" on page 13.
8. Verify that the Tri-sensor cable is plugged in. Plug it in, using care to orient it correctly before insertinginto the unit.
9. Clean the cell if clogged with debris or calcium scale.
10. Check for air in the bypass manifold by loosening the top union on the cell to see if air or water comesout. If air comes out then there may be a vacuum side leak or the pump may be undersized. Check forleak at pump basket o-ring, leaking valve or fitting.
11. If the pump is a 2-speed pump, is it on low speed? The low speed may not create enough flow for themanifold. If using a variable speed pump, increase the RPM.
Owners manual attached.
