Flying Tivo
- Jan 24, 2017
- 3,100
- Plaster
- Pentair Intellichlor IC-40
The filter is not needed to move water, water just passes through the filter. If you remove the filter media(grids) the water is just going to recirculate. Just as recirculate on a MPV which the OP does not have. Also his filter is quite small and will have to clean it every few hours which is tedious at best. What i meant is to run in recirculate mode for a couple of days until all algae is dead. Then insert. the filter cartridge and. start the filtering process.Why not use filter, water needs to move.
