Air has been seen in the filter window as well as coming out of supply ports in pool.
A well-respected leak detection company came out and after 2 hours of investigation said that there is a leak in a line under this section of pool decking om the marked area. He heard strongest leak sound (a gurgling) at the arrow:
Two quotes to repair have been in the $2200 to ~$3000 range for:
cutting open the concrete, excavation 2-3' deep, and line repair(s).
I've cut open concrete, know how to dig in dirt, and have cut/glued PVC. Is this a more complicated operation that I shouldn't try?
Is there any concern about cutting the decking too wide will somehow compromise the pool structure (concrete/plaster pool)? This area indicated is about 3' at most.
Any comments/suggestions greatly appreciated!
