Hi -
so my question is about the water level after the pool is closed. My pool was newly done with Diamond Brite about 3 months ago. it looks great. I am worried that over the winter when the water level drops below the tile line that I will get a ring around the plaster. Is this true? Should I try and keep the water filled up above the tile line, but then the water is over the skimmer entry (which I will have plugged of course and with a empty plastic bottle in the skimmer). So water will not get into the lines.
Doesn't matter what gets added to the pool when closing, obviously the water will get black, nasty and full of leaves and debris... it cleans up fine in the summer, but I wonder about this water line...
Thanks...
Thanks...
