This is day 3 of SLAM.
I am still losing a ton (that doesn't even feel like an exaggeration) of FC each day. After a broken vacuum, we now seem to be making progress. That said, I wanted to just get a sanity check from the pros.
I started with a swamp last week. Drained, refilled, fixed a floating liner, retested, and started SLAM. I work from home, so able to test/SLAM every 2-3 hours pretty easily. My SLAM level is 12ppm and I'm averaging a loss of about 6ppm every 2-3 hours during sunlight - and my overnight loss is around that amount as well. I have an 11-year old that is mastering the art of vacuuming, so she is working on that in parallel to get all the algae and calcium deposits out. She vaccums and empties the bucket in 15-minute increments throughout the day and I test and add chlorine every 2-3 hours.
Should I be testing my FC again 20-30 minutes after adding chlorine to ensure I'm getting to SLAM level? I have been following the suggested amount (give or take a few ounces here and there), but I haven't ever confirmed it's getting to 12-ish each time.
Also, given where I started, I'm just glad that while vacuuming, we can sometimes see the vacuum... if I were to guess, the amount of gunk still settled down on the bottom and floating around is the biggest obstacle and my SLAM numbers will start to improve as the removal of debris continues. Does that sound right?
Thanks all!
