Keep going to chlorine level 24?Slam on, should only help with the stains if they are organic. Keep brushing.
Add as often as you can, 2 hours is not too much. The more often you test and add chlorine, the faster SLAM works...We are continuing to add liquid chlorine a few times daily and the pump is running 24/7
It was a loss of 6 ppm overnight. So I guess I have a ways to go yet.Have you tried an Overnight Chlorine Loss Test yet? What is your overnight loss from a test after dark to a test before dawn? That should give an idea of how close you are to complete too.
Will it help at all to lower phosphates in the pool? Or should I worry about that later once the algae problem is fixed?Keep slamming.
No-Will it help at all to lower phosphates in the pool? Or should I worry about that later once the algae problem is fixed?
Thanks! Everyone here is so helpful. This process is so overwhelming, but all the advice has been great and makes it easier.No-
no reason to worry about it later either so long as you maintain adequate fc for your cya going forward
FC/CYA Levels
Yep - keep it going, and try to find anywhere that algae could hide. Inside ladders, niches behind removable lights, the skimmer throat, back of the weir door or the foam on it in the skimmer, etc. Gotta scrub those out and let the SLAM level chlorinated water get everywhere in them.It was a loss of 6 ppm overnight. So I guess I have a ways to go yet.
No, it is your TA. If you pool likes 7.8, leave it there.My pools likes to run high on PH but normally the MA brings it right down. Is this a side effect of slamming?
Comparison block basically tell you if you have chlorine, FAS-DPD tells you how much. Chemicals do get old. What is the date on the reagent?Also, when the chlorine got under 10 I tried using my regular comparison block to measure chlorine and it showed 1 which I knew couldn't be right. I used the FAS-DPD kit and it was 6.00. I've been testing the chlorine level using both kits and they never match up. Right now, the comparison block shows barely any chlorine, the test is only the faintest pink but the FAS-DPD test reads 4.00. Do the chemicals get old or expire? I'm not sure what to make of that.
I think the reagent is expired. I'm going to get rid of it. I don't trust it ever since I started using the FAS-DPDNo, it is your TA. If you pool likes 7.8, leave it there.
Nah. Anything in the 7s is fine. Here is what happens. With a TA between 60-80, your pH will likely sit at 7.6, 7.8 maybe 7.9 or 8 and not rise much. If you have high TA, your pH tends to rise. So best course of action is to let pH rise to 8, then reduce with Muriatic. That will reduce TA and pH. After some number of cycles, your pH and TA will be in equilibrium. Different in each pool, but 60-80 TA and pH 7.6-8 and pH won't rise anymore.Isn't 7.8 too high for PH ?
Good advice, thank you!Nah. Anything in the 7s is fine. Here is what happens. With a TA between 60-80, your pH will likely sit at 7.6, 7.8 maybe 7.9 or 8 and not rise much. If you have high TA, your pH tends to rise. So best course of action is to let pH rise to 8, then reduce with Muriatic. That will reduce TA and pH. After some number of cycles, your pH and TA will be in equilibrium. Different in each pool, but 60-80 TA and pH 7.6-8 and pH won't rise anymore.
So...let you pH rise to 8.0. Reduce to 7.6. Rinse and repeat, when the number of days it takes to rise to 8 slows, and your TA is 60-80, then let pH sit where it likes...7.6? 7.8? even 8...
to be accurate, the pH rise will slow to the point it is manageable...some pools, the pH will not rise. Areas with High TA fill water and high evaporation rates may need to add muriatic quite frequently. You have high evap rates. Do you have a solar cover (likely not)? Test your fill water for pH, TA and CH. Report back...and pH won't rise anymore.
No solar cover.to be accurate, the pH rise will slow to the point it is manageable...some pools, the pH will not rise. Areas with High TA fill water and high evaporation rates may need to add muriatic quite frequently. You have high evap rates. Do you have a solar cover (likely not)? Test your fill water for pH, TA and CH. Report back...
You haven't shared your logs. PoolMath, home page, gear in upper right, scroll to the bottom and enable sharing with TFP. Make sure you are using the same login as TFP...
