Ok I got my test kit last night and as soon as I had enough light to do the test accurately this is what I got
We have been doing pool store run around and chlorine forever so I am very excited to get this pool soup taken care of.
Our main issue is algae but with brushing and chlorine it is almost gone except for some in the corners and small amount on deep end wall. I will pick up a corner brush today.
I have been adding chlorine and brushing daily except for yesterday.
FC - 0
Ph - 8.0
TA - 120
Ch - 150
CYA - 0
So according to pool math
Chlorine - 2 gal, 1 cup of chlorine of 12% pool store chlorine
Ph - 25 oz Muriatic Acid
TA - ?
Ch - 195 oz of Calcium Chloride
CYA - 64oz or 4 lbs of CYA ( I am going to start with 3 lbs then test again this p.m.)
Ok so I read that CH should not be adjusted the same day as other chemicals so I will adjust chemicals and it is a very cloudy day so do CYA and Chlorine asap along with brush and vacuum is my plan and will pick up muriatic acid and Calcium Chloride when I run errands today.
When should I rinse filter again, I have a new filter but don't want to put it in until the pool is somewhat in balance.
Does this sound reasonable?
Thanks in advance for your help
FC - 0
Ph - 8.0
TA - 120
Ch - 150
CYA - 0
TA - ?
