Just adding an update on progress. I didn't get to make it home on my lunch break to do my normal cleaning and honestly was very discouraged yesterday. To my surprise yesterday the water was even clearer than it was in the morning. Even my wife made a comment that it was looking better. The water is still hazy, but you can make out the pattern of the liner in the shallow end. After I did my normal cleaning routine I decided if my FC was lower than 10 I was going to run a full set of tests. I didn't bring my log book with me this morning so I will post the full results when I get back from lunch. But what I do remember. FC: 8, CC: .5, PH: 7.0, CYA: 30. Note:I did test my cya in the house last night because it was dark out side and I wanted to know what it was. I know this should have been tested in the sunlight. Also, in just my kitchen light I could still barely make out the dot. So I am confident I would have been able to see it in the sun light. I went ahead and added a small sock of CYA and will test it again this afternoon.
I know my PH is a little low, but I went ahead and brought the pool back up to shock level last night because I didn't want algae to start growing again as the water warms ups during the day. When I tested the FC this morning before work it was 12.5.
For anyone that is keeping up I think I have some factors that have been helping me out. This is all my theory anyway
1. We have had a cold snap in arkansas the last couple of days with lots rain and my water temp dropped from 61 to 55.
2. I added some DE to my sand filter because it ran for almost two days with no pressure change from a backwash.
- I have followed my manufactures suggestion of backwashing at 8 to 10 psi over my normal.
3. I wouldn't say I was back washing excessively, but I have fought the urge of backing washing before going to bed because I didn't want to get up in the middle of night to check on it. Effectively I think I have let my filter build up some sediment to start capturing smaller particles.
