- Jun 24, 2021
- 16,041
- Vinyl
- CircuPool RJ-60 Plus
That's the stuff!Is this one okay!
Should I turn off filter at night in case PSI goes up too much? Do I need to actually watch it for 24 hours?That's the stuff!
How fast does it get to 25% over clean pressure? If over 12 hours, then backwash the DE out and leave the pump on.Should I turn off filter at night in case PSI goes up too much? Do I need to actually watch it for 24 hours?
It hasn’t gone to 25% in two days now. Stayed at same PSI for around 48 hours.How fast does it get to 25% over clean pressure? If over 12 hours, then backwash the DE out and leave the pump on.
Read the last bullet in "prerequisites" in the SLAM process. Link-->SLAM Process
so before I go to sleep if I backwash it will backwash the DE witb it?How fast does it get to 25% over clean pressure? If over 12 hours, then backwash the DE out and leave the pump on.
Yes.so before I go to sleep if I backwash it will backwash the DE witb it?
Okay did it. Only half a cup of this stuff brought it up 1 psi. Not the 1-2 cups it says. But anyways. Just watch it for now? When do I add more DE? or not until I backwash and start again?Yes.
Great. Instruction on TFP say to add in 1/4 cup increments. TFP, not the box.Okay did it. Only half a cup of this stuff brought it up 1 psi. Not the 1-2 cups it says. But anyways. Just watch it for now? When do I add more DE? or not until I backwash and start again?
Oh yeah I added 1/4 at a time. Ended up being 1/2 cup that made it go up 1 PSI. Ty!Great. Instruction on TFP say to add in 1/4 cup increments. TFP, not the box.Add another half cup AFTER you backwash. Watch the pressure more carefully for the 25% rise with DE in the filter.
Just use it up over time, or store it.Now what do I do with the 25 pounds of DE I now have![]()
Could be placebo but I swear I see this getting clearer already due to DE lol already had to backwash once and add againJust use it up over time, or store it.
Only enough to raise pressure 1psi at a time
Loss of 4ppm last night. Still super cloudy. Day 7. Guess I still got work to doIf you pass multiple OCLT's, then let us know.
So look at it this way. You need X amount of FC to clear your pool.Loss of 4ppm last night. Still super cloudy. Day 7. Guess I still got work to do
I may have missed the weir doors. I have 2 so may be the cause of the issue?Yeah, this is the point it gets hard. Time for POP.
Where are you at brushing the inside of ladders, behind lights, in the skimmer, removing and scrubbing the weir door?
Post a current picture of the door.
