- May 10, 2021
- 18
- Plaster
- CircuPool Core-35
Hello all,
Just beginning to learn about owning a pool here. I'm in Massachusetts, and inherited a gunite pool which hasn't been used by humans in probably a decade. Still working on getting it clear of debris (leaves, branches, muck and other junk), then on to pressure testing each of the supply/return piping lines, and then will be figuring out the extent of refinishing necessary (and consulting gunite pool builders / refinishers). Also need to select a chlorinating system, and do some research on wireless control systems so ideally I can manage the equipment (pump, chlorinator, pool and deck lights) from my phone and/or from inside my house. I also want to put in a heater at some point just to make the pool more comfortable during the summer season, and am leaning towards an electric heat pump (gas line is 150 ft away and I don't want to be filling propane tanks). Looking forward to learning a lot here and having this forum as a resource.
Aaron
Aaron
