After reading another thread (
Open letter to Mr. Pool Builder... - Page 2) about cramped equipment pads, it got me thinking about how my equipment should be set up.
At the pad, I have a line for the main drains, a line for each of the 2 skimmers, a single line for the 3 returns that get tee'd under the deck, a single line for the 2 sheer decents (with a valve behind the wall already to balance the flow between them) and a return line for each skimmer since they are venturi skimmers (
Renegade Venturi In-Ground Skimmers).
Given this, I assume I want a 3-way valve between the two skimmer suction lines to balance skimming action? And then another 3-way valve between the output of the first to balance the suction of the skimmers versus the main drains?
And then that valves output will go to the pump, to the filter, to the SWCG?
It is the pressure side that has me a bit stumped. I'm also plumbed for a pressure side pool cleaner, which I won't be using but I asked for the plumbing to be in place. (I don't even care if it's just capped off for future use.) If we cap the cleaner line, that still leaves 1 line for the 3 returns, 1 line for the 2 sheers, and 2 lines for venturi skimmer returns.
Any ideas how the pressure side should be plumbed?
I just want to make sure this is done most optimally, even if it means paying the builder for a couple more valves. (Do it right the first time!)
EDIT: And I'm definitely asking him to space things out a bit, even if it means losing a the use of a few more feet of decking.
EDIT 2: I'm not sure what the builders plans are for the pad, so I can't say they won't do it right to begin with. I'm just not familiar enough with this stuff to know if what they are planning is optimal. Since the lines are going through the deck, I'm also going to ask him to leave some room vertically to ease future replumbing. I don't want to find myself tearing up decking to replumb in the future.
EDIT 3: Because I'll have automation (iAqualink), I believe the valve that controls flow to the sheers should be automated to allow for turning them on or off.
EDIT 4: This is a rough idea of the stubbed layout at the pad currently.
Skimmer Return - Skimmer Return - Sheers - Vac - Skimmer - Skimmer - Main Drain
