I got a bit behind here, so here's an update:
May 21, 2018 - Orientation
Friday was orientation day... had a smart guy come out to show me how to work things. He quickly figured out I knew a bit more than most and we discussed things a bit deeper, just as far as water chemistry and equipment/plumbing goes. We set up automation/control of the lights, and the valve actuator for the sheer descents, and I got a tour of iAqualink so I can adjust schedules and run times going forward.
He did point out that the return lines for the venturi skimmer returns were plumbed on the wrong side of the equipment pad. They way they were plumbed they only came on when the sheer descents were on, where it should be the opposite. He also agreed that the pool needed added calcium and added it to his punch list.
May 24, 2018 - Pump Dies
Thursday evening I'm in the back and everything is running. I go to talk to my neighbor, and then bring him back to look at the finished job, and the pump had turned off. I reset breakers, turned off the automation and tried to start the pump manually (in Service and Timeout Mode on the panel) with no luck.
I call the company first thing the next morning (a Friday) and explain the situation. They are getting slammed due to the season and the weather, but they can have someone out next Wednesday, but of course this means no circulation (or swimming) over the 3 day weekend.
May 25, 2018 - Re-plumbing
Unknown to us, or the builders service department, they had a truck scheduled to come by on Friday to re-plumb the venturi skimmer returns (as noted during Orientation). When we mentioned that the pump also died, they took a look and received approval from their shop to swap it out same day while they were there anyway.
They also explained that the skimmer return lines should have originally been plumbed to the right-side of the return plumbing rather than the left. I really wish somebody would have noticed it before the deck pour and now I have this funny looking "U" plumbing. I really should have pushed for a basic diagram of the plumbing like I originally wanted to. Oh well, it could be worse I suppose. All fixed now anyway...
Swim Time!
We've finally been able to start swimming. The water's still pretty cool, low/mid-70's, but that doesn't stop us on the warm days. We had 90+ degree temps on Memorial day so we spent a decent amount of time in the pool. At this age they can't go too long till they get tired, and they did sleep quite well that night.
Landscaping Continues....
I'm still plugging away at the landscaping, trying to get things to a decent state prior to 2 of the kids combined birthday pool party on June 10th. The retaining wall is basically done, though I'm putting off installing the cap blocks until after as there are other priorities. Drainage pipe is in behind the wall and crushed rock backfill complete.
I put a valve box around the Jandy valve that's used to balance the water flow to the sheer's. This way it won't get buried as I start putting excess dirt everywhere.
And dirt.... I've already moved wheelbarrow after wheelbarrow of this stuff and there's still more. I'm putting it everywhere I can for now, but I'm nearing the end of places that I "need" it. Now I'm just starting to look to get it out of my way. I've also started trenching for the sprinkler lines....
There's a week and a half till the party and still so much to do.
