Hello,
We recently bought a home that has a pool. I have never owned or maintained a pool and have zero knowledge on the subject. The pool is currently dark green. We had a Hayward chlorine generator installed to convert to salt water. The installer told me I needed to shock the pool first before putting this unit into service. Do you have any recommendations for products or proceedures to use to get the pool in shape to begin using the chlorine generator? It is an in-ground pool that the chlorine generator installer estimated to be around 23,000 gallons. His recommendation was to shock, then take a sample to the pool supplier, and have them recommend where to go from there. I have ordered a Taylor test kit, so I may be able to avoid the pool supplier. I would appreciate any advice you guys could give.
Steve
Steve
