Hello! I am a first time pool owner. I have the Taylor k1004 test kit and the pentair cyanuric acid test kit. When I had the pool installed, my goal was to use liquid chlorine but of course that has been hard to come by this year. (I just saw liquid bleach at Walmart this week for the first time in a couple months). So I have been using trichlor tablets and powder shock for the time being.
anyways, I need some guidance with my test results. This morning I had: FC 5, CC 5, ph 7.8, CYA 40, and TA 140. Do I need to bring down the TA? Or will that naturally begin to happen as the pool is used more? To switch over to the slam method, how much bleach would I need to have on hand for regular maintenance? I don’t want to start it and then be in a situation where I can not locate bleach anywhere. I would like to try and build up a small stockpile before changing over.
Thank you for taking the time to read my post!
