I would not leave that liner alone like that if you plan to swim this season. I know you've got your hands full with the SLAM, but you don't want water getting behind the liner. Even rain will be getting in there. The liner patch is your best bet. I had a liner pull out years ago that I could not pull back into place. I limped by a couple seasons with the vinyl liner patch that I got a a pool store. That will be your best bet. It may not look pretty, but it will get you through.The schedule is difficult because I haven't moved in yet, so I'm having to stop by a couple times a day. But that changes this weekend.
Yeah, a friend said the pool store may be able to sell me a large enough vinyl patch if I wanted to go that route, but honestly I'm going to try to just limp along until next spring I think.
Thanks for the input! The previous owners mentioned they swam with it this way last year, so I thought it might be ok. What's the risk for water getting behind the liner? I must assume it's been this was at least a full calendar year at this point. Should I be concerned?I would not leave that liner alone like that if you plan to swim this season. I know you've got your hands full with the SLAM, but you don't want water getting behind the liner. Even rain will be getting in there. The liner patch is your best bet. I had a liner pull out years ago that I could not pull back into place. I limped by a couple seasons with the vinyl liner patch that I got a a pool store. That will be your best bet. It may not look pretty, but it will get you through.
Good luck with all of it and keep fighting!! It will be worth it in the end!!
Could wash out any soil behind the liner and may let your deck sink if water washes it out. Could corrode any metal structure behind the liner. Or I could be over reacting and nothing could happen. But, I would not leave it that way if it were my pool.Thanks for the input! The previous owners mentioned they swam with it this way last year, so I thought it might be ok. What's the risk for water getting behind the liner? I must assume it's been this was at least a full calendar year at this point. Should I be concerned?
The photo above is the deck side canister for the in-floor cleaning system. If you can get a good clear view of one of the popup heads in the floor, it would have some marking that tells you the kind of system you have. There are online guides to help you identify the kind of system you have. - Paramount Pool & Spa SystemsVacuum situation isn't great. I have a hose but no vacuum head. I almost bought one today but am concerned. I don't seem to have enough suction from the skimmer basket to put my hose there (I think that's where I'm supposed to put it right?)
I think the low flow/suction is because of the in floor cleaning. There's a large drain at the deep end that I think pulls in a lot of water. Or maybe it's this other moderately sized diameter thing that's pulling in water. I'm just not sure how all the plumbing works.
There's also this second box near the skimmer that I'm not sure of it's function either.View attachment 581769View attachment 581770
I might have the original owners manual. The sellers left me a lot of documentation that I have shamefully not had a chance to read all of yet.The photo above is the deck side canister for the in-floor cleaning system. If you can get a good clear view of one of the popup heads in the floor, it would have some marking that tells you the kind of system you have. There are online guides to help you identify the kind of system you have. - Paramount Pool & Spa Systems
I think I got all the plugs out, and the basket does fill. There was a large(ish?) mesh net filter that seemed to fit perfectly in the basket.If I'm seeing this right, the line from the main drain to the deck canister is still plugged. We have this same canister, and the plug in the side looks like a Schrader valve that you use at the end of season/closing to blow out the line from the canister to the main drain to create an air lock, so set that aside, or mark it to be reinstalled in that port at closing. The port at the bottom is the suction line to the pump.
Yes there is! I'll attach a photoIs there an opening/plug in the wall of the pool right next to the deck canister? If so, that is an equalizer that allows water from the pool into the canister, and it's part of the system design to hold the clear lid in place inside the canister.
Yep, I'll attach some of those too.I'm curious what your equipment set up is? can you share photos of the pad?
Wow that is amazing, I may contact them for this reason alone.ALSO! if you're a document and manual collector like we are, you can probably get the system plan for the paramount system directly from Paramount. The pool builder was not able to supply us with any plans or diagrams, paramount still had their drawings on record from 10 years previous.
