First time opening the pool and got the water cleaned up but noticed what I believe is MA on the floors and benches and sun ledge.
Cya 70
TA 140
Got ph to 7,4 before slamming
After passing SLAM I noticed the pooping during brushing. I forgot that if it it’s mustard algae you have to increase FC even more for 24 hours. So I reslammed and then went up to 42 FC. Brushed daily. Kept it at 42 for 3 plus days and still have MA. It has improved though. At the beginning every slot of the floor would Poof when brushed. I should add that it’s very hard to see because we have a darker pebble tech finish. After being at 42 for 3 days the floors are mostly clear but it still shows up on the steps and tanning ledge and bench. Basically any raised surface. I got frustrated and just raised FC to 50 last night. Over night didn’t lose anything. Was out of down during the day. Got home in the being and tested and it was down to 32. Water temp has been in 50s. It was too dark to see what the ledges looked like tonight. I’ve kept the pump running all the time and my Polaris cleaner most of the time thinking it would help. We have a sand filter. Backwash it every couple days while slamming.
We do have a spill over spa that spills onto the sun ledge. I have not taken off the lights to clean but I don’t know how to do that.
At this point I don’t know what to do. I’ve spend a ton of money on chlorine. I don’t want to add copper based algaeicide but it’s tempting me right now.
I’ll add that this is very hard to do when I’m gone during the days
Maybe I should replace some water and lower cya and reslam. I do have a swg and it is about warm enough to use it now. Not sure the max chlorine it could provide
Cya 70
TA 140
