This summer our family is finally getting an Intex pool. I've set up a few of these for friends and family, but now that I'm doing it for myself I'm getting a little obsessive with the prep work. Reading various forum posts and watching numerous YoutTube vids, I plan to level out at area of my yard by using the water level approach, then plan to do the insulation foam bottom and lastly use pavers for the legs.
We have a 20' Intex Ultra XTR and wondering if anyone can share more exact measurements? I'm trying to do as much prep work and measurements ahead of time as I can. Therefore I'm curious the spacing between the legs and also if the 20' diameter is measured from the outside to outside of the frame or if from the inside? I'm wanting to make sure that the circle I level out will have enough room for the foam and pavers. Should I prepare for a 21' or a 22' circle on the ground?
