OK, so I'm opening for the first time this spring... Pool installed late last year after it was too cold to swim, so I basically just did a closing only. Using a TF-100 test kit.
pH - 7.5
CYA - not measured yet, but put in 5 lbs of stabilizer yesterday
FC - Double-shocked it last night. Currently about 6.
Calcium - About 90
TA - About 250. Checked it a few times. Verified with a test strip as well.
(Yes, I did wipe the bottle)
So, I tested my source water... TA of about 250. (Filled over the course of about a week and a half, via a well with a water softener due to iron). Due to the distance from street to house/pool, water delivery would not be a real option. Distance is 600-700 ft. Too much hose, and a truck would destroy the driveway.
Water looks good, if not a touch cloudy.
What should my treatment plan be? I added some citric acid when I opened (had some rust stains) which cleared things up, but lowered pH to 6.8ish. I have been aerating to get the pH back up.
Am I resigned to pouring in gallons upon gallons of acid to get TA down? (so... Like, every day or two, a gallon of MA, then let my water aearate to raise it back up to 7.5 or so, rinse and repeat)
pH - 7.5
Calcium - About 90
