I've been a pool owner for the past 5 years and through what I've learned on this site, I have always had perfect water.
Today I opened to a cloudier than usual pool. My opening numbers were as follows:
pH 8.2
FC 0.5
CC 3.5
TA 50
CYA 0 (or at least I filled the entire tube and could still see the dot)
Seeing the CC of 3.5, I knew I needed to SLAM, but I have never had to do this before so that's the reason for this post.
First thing I did was add enough muriatic acid to take the pH down to 7.5.
Next I added enough stabilizer to a skimmer sock to give me an additional 30 on my CYA. Figured if my CYA is actually 20 then I'm only going up to 50.
Then using the chlorine CYA chart, I added two gallons of 12.5% liquid chlorine to get me to an FC of 10. (I had added one gallon a few days ago before the official open)
About an hour later I tested for FC but it was still pretty much at 0. I added another gallon, but I'm not sure how long to wait to get an accurate reading?
Am I doing this right? Do I just keep dumping liquid chlorine in until I get to an acceptable FC level? Or is there something else I should be doing before adding chlorine?
I am of course running the filter non-stop and brushing the floors and walls.
Thanks for all the help. I'm sure I will get this worked out thanks to this awesome website.
pH 8.2
FC 0.5
CC 3.5
TA 50
