20 ounces for your pool should give you 10ppm rise in CYA so if your not quite 30 but over 20 give 1pound of stabilizer and begin slam immediately, not necessary to wait.
That seems reasonable. Thanks!
I believe it’s a positive false……. Or a would that be a false false ? Oh man !! Now my brian hurts. THANKS !!! But yeah, if the unit ate 1 FC you may have failed when you passed otherwise.
I believe the units simply unplug from their power source. Not sure if it’s an outlet, automation or a another controller, and it may be a twist-and-pull, but you should be able to easily pull the wire.
Because builders only know the kickbacks that they get from the manufacturers and typically know bupkiss about maintaining the pools they built.And then explain to my wife why I'm unplugging the new piece of equipment that was installed with the pool.
How comfortable are you around electricity? If not comfortable, pay someone to do it for you.
That being said, shut off all power to the EasyTouch and pool at the main breaker panel. Open the EasyTouch and trace the UV wires to their termination. Disconnect the wires for the UV at their termination point, wire nut the ends of the wires and tuck the wires out of the way. Put any removed panels back on and repower the EasyTouch.
Once again, if you aren't familiar with electricity, have someone who is do this for you. Safety first.
You already have a bucket of tabs, and you need CYA, so have you considered using some 3in tabs now?Going to add more LC. Haven’t had a chance to add CYA yet.
Stay the course. You got this. Life gets busy for all of us, do the best you can.Appreciate everyone giving advice. I’m a little frustrated right now but I know I will get there
Pics or it didn’t happen. Sorry but these are widely accepted internet rules, across the world. I do not get to make the rules.The good news is the water is clear and the wife and kids are swimming happy
Blank slates are beautiful too. Might spawn some cool ideas from folks. Just sayin.Pics to come. I have been holding off because it looks bad without the landscaping done. I’ll try to snag a decent one tomorrow
Way to go !!!!!I think I'm slowly starting to get the hang of it.
