Hi! We received our TF-100 test kit and I just completed the first tests. We have a new pool with Pebblesheen plaster.
Here are my results:
pH 8.2
FC 1.0
CC 0.5
TA 130
CH 150 (was blue and then 15-20 seconds later turned back to red, so I added one more drop. If I count that last drop, then it's really 175.)
CYA 0 (I could see the black dot until the test tube was completely filled)
Water temp 57F
I have liquid bleach and muriatic acid that I can add. The Pool Math website also recommends adding calcium chloride for the CH level, and stabilizer for the CYA. I don't have any of that, but I can get it tomorrow.
Our project is still under construction, and we haven't had pool school yet. The PB is still using tabs in the chlorinator. I want to start getting these levels corrected though ASAP, so I'm going to start taking care of the water.
Recommendations from Pool Math are to add 83 oz of the 6% bleach, and 52 oz of the 31.45% Muriatic Acid. Should I go ahead and add that now, and then get the calcium chloride and stabilizer tomorrow?
Thanks for your help!
pH 8.2
FC 1.0
CC 0.5
TA 130
Water temp 57F
