Months ago I bought a house with a pool. I've been letting the pool guy they were using do... whatever it is he does, I'm not 100% sure. He mainly vacuums and uses the net. He replaced the ball float auto filler that wasn't working (pool level fell below the skimmers). He throws a tablet of something in each of the two skimmers. I've not seen him doing any tests, though to be fair I haven't been watching him closely. I want to take over balancing the chemicals. I'll still probably have him vacuum, though maybe less often. He's been coming once/week.
I got a TF-Pro kit and did the tests today, results here:
I used 2900 min, 3100 target, 3400 max for salt. Are those the right values?
How bad is it? What should I do from here? Which problems are most pressing and should be addressed first?
It's a 10,643 gallon plaster pool that is ~3 years old. It has a SWG (Autpilot PPC1 digital, 1.28lbs/day CH) and a DE filter (Hayward). It looks like this:
There's 2 Pentair pumps. They were both set to 3400rpm (max), but I've reduced them a lot after getting a high electricity bill. The pumps:
What do you think about the pump speeds and schedules?
Lastly, one of the 3 pool lights stopped working. On the back it says Hayward LPLUS11100, so it appears to be a "Colorlogic":
I found this Pool Tone light that seems more reasonably priced than most. Will the transformer/etc work with the new light if I just replace the broken one with this? I understand the wire comes in a specific length, so I guess I'll have to pull a new wire all the way to the pool equipment? That sounds like a nightmare, maybe the pool guy can do it.
I wonder if I should replace all 3 lights at once? Else the trims won't match. There are 2 big lights and 1 smaller (~6") light.
That's everything! Any advice at all is appreciated. This is my first pool, so it's all new to me!
- Pump 1 is for return jets in the seating area on the right. I don't think these really do much. The pump runs at 1800rpm for 2 hours/day (when pump 2 is off).
- Pump 2 is for the return jets 1-3 and runs at 1800rpm for 6 hours and again later for 2 hours each day.
- There's a third, different kind of pump for making bubbles in the seating area, but it's very loud and I never use it.
