FC 9
CC 2
PH 7.7
CYA 42
TA 70
CH 700
Salt 2800
Please advise, I'm aware a few are not in ideal range.
CC 2
PH 7.7
CYA 42
TA 70
CH 700
Salt 2800
If a bunch of stuff got washed in, I suppose.Going off the directions of the test it was 2. No covered and pool is clear and good looking. It did rain all day today so maybe that's throwing it off?
You should try to capture as much rainwater as you can to reduce the CH. That's just for the future.
I would leave the CYA where it is for the moment and raise the salt and turn on the SWG. And if it still shows high CC, then you SLAM. Otherwise, then you raise CYA. Somewhere in there the pH will probably need adjusting. It's okay for now.
I'm not sure what your SWG calls for. I'm a Luddite jug-dumper. But the salt needs to dissolve and circulate for 24 hours before the SWG goes on, so you still need to be testing FC & pH every day. You'll know by the time the SWG is ready whether or not the CC has cleared up.Ok it's supposed to rain the next few days, 40%-60% so maybe that will help reduce the CH.
How much should I try to raise the salt, 3200?
Also, how long would you recommend waiting to do the next test after adding salt and letting SWG run?
Give it time. You have plenty of FC right now.Based on pool math app, I brought my salt up to 3000 and it's still circulating. I tested FC and CC:
FC - 7.5
CC - 0
PH - 7.7
Should I turn the SWG on or give it a full 24 hours?
If you plan to SLAM, leave the CYA where it is. Round up to 40 and use 16 as the FC level. If the water is clear and you don't need to SLAM, raise the CYA so the SWG and/or the pump can be turned down some yet still maintain FC according to FC/CYA LevelsTest results from tonight:
FC 5.5
CC 0
PH 7.6
CYA 35
TA 90, at 7 and 8 drops it turned clear, then red at 9?
CH 200
Salt 3000
Cya dropped a few and CH dropped a lot, although I might not have done the rest completely right the first time. Do I need to get the CYA up then SLAM? My pool was cloudy/green last week and Leslie's said to add salt so I did and it made it worse. TFP said to add liquid chlorine until test came in. Pool cleared up and looks great today. Not sure where to go from here?
Any recommendations on products to use to raise the CYA? Leslies conned me into a $40 bottle of stabilizer but might need more based on pool mathIf you plan to SLAM, leave the CYA where it is. Round up to 40 and use 16 as the FC level. If the water is clear and you don't need to SLAM, raise the CYA so the SWG and/or the pump can be turned down some yet still maintain FC according to FC/CYA Levels
Yes. Cyanuric Acid granules available in the pool section of most big box stores. Recommended Pool Chemicals - Trouble Free PoolAny recommendations on products to use to raise the CYA? Leslies conned me into a $40 bottle of stabilizer but might need more based on pool math
