Admittedly, I was intimidated when I first opened my new TF100 kit today, I’m a corporate tax professional not a chemist, so i had anticipated it was going to be above my abilities, but it actually turned out to be absolutely user friendly. Great step by step instructions guides you right thru the process quiet easily. So here are my results from testing done around 2pm.
FC- 1
CC- 0
TC- 1
CH- 275
TA- 280
CYA- 20
CSI- -0.24
PH- 7.0 (with PH009 Pen Meter)
PH- 7.8 (with Testing Block & R0014)
Salt-4600 (Taylor K-1776)
Drained and refilled 30% of water yesterday in order to install thru wall skimmer.
Have not be operational with a SWG for a week now due to equipment failure but have another ordered & arriving in 10 days. (Salt reading is high due to that machine continuously alarming with low salt light and me adding salt each time, yes my big mistake there was trusting the intex SWG to be correct about the low salt alarm)
I did the pool math app & added a 11 oz of Sodium Dichloro
To bring up the FC.
Considering I will have no SWG to run for the next 10 days, i knew I would need to bring up the FC but other than that I wasn’t sure about what other of these testing results I should attempt to balance and in what order to balance them. CYA, CH, TA all missed their target ranges and I’m not at all clear on why the two PH testing results are different from one another. Can someone please advise me as to what to do and in what order to address them?
Also, I have been running the pool pump 12 hours each day. Should I decrease that time or continue that schedule?
FC- 1
CC- 0
TC- 1
CH- 275
TA- 280
CYA- 20
CSI- -0.24
To bring up the FC.
